Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
TLS2.0 Key (username)=(admin) already exists issue
Lin__Joey
Innovator
Dear EIS Team,
The error log attached appears after running ./setup_TLS_docker.sh
Please provide your expertise. Thanks in advance,
Joey
WengWai_C_Intel
Hi @Lin__Joey
For the key already exists message, basically it will not cause any issue and from your logfile we can see the 5 cvat related containers (cvat,  nginx, cvat_cvat_ui, redis and postgres) already up running. In order to have a clean rebuild, below are some suggestions for you to re-run the setup:
1) Go to path <TLS_repo>/webservices/components/cvat directory, run the command below:
     sudo docker-compose down
2) Go to path <TLS_repo>/ directory, run the command below:
3) Run the command below to remove the directories:
    sudo rm -r /opt/intel/tls
4) Go to path <TLS_repo>/thirdparty directory, run command below:
    sudo ./cleanup_docker.sh
5) Finally, in the same directory, run the setup script again without sudo.
Let me know if you can rebuild the system and running.
Thanks!
JesusE_Intel
Hi Joey,
Thanks for reaching out, the DETAIL: Key (username)=(admin) already exists is alerting that the user name exists, likely the command was previously executed.
However, the issue indicates there is already a docker container with the device /opt/intel/openvino.
ERROR: Configuration for volume openvino specifies "device" driver_opt None, but a volume with the same name uses a different "device" driver_opt (/opt/intel/openvino). If you wish to use the new configuration, please remove the existing volume "training-and-learning-suite_openvino" first:
If possible, please try to clean the docker containers and re-run the setup_TLS_docker.sh script. Please note this will completely remove the docker contains and they will be re-downloaded.
cd <TLS_repo>/thirdparty
sudo ./cleanup.sh
Jesus
Lin__Joey
Innovator
I tried it with no luck with error log attached. Does that mean the keys stores somewhere else in the system? The error appeared after I failed to restart TLS docker.  It baffles me for the correct procedure to restart the TLS server.  Do you have any other suggestion?
Thanks a lot,
Joey
WengWai_C_Intel
Hi @Lin__Joey
Thanks!
JesusE_Intel
