Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Temperature Issue in Intel RVC evaluation environment
Chinatsu_Miura
Greetings,
When booting with ECI_Debian, there is a phenomenon that the temperature of the PC rises compared to when booting with normal Debian.
The customer confirmed with the following command.
cat /sys/class/thermal/thermal_zone1/temp
CPU utilization comparison
・Normal Debian: about 1-2%
・Debian + ECI: about 0 to 1%
Temperature comparison
・Normal Debian: 37 degrees
・Debian + ECI: 75 degrees (rises to 84 degrees after startup, settles around 75 degrees due to high fan rotation)
The customer confirmed using the following Laptop PC.
https://www.pc-koubou.jp/products/detail.php?product_id=871229
We tested both ECI v3.0.2 and ECI V3.0 environments on the Intel NUC.
Neither of these have reproduced this phenomenon.
Intel NUC: SWNUC12WSHi7000 (CPU:i7-1260P)
This phenomenon is only seen in the customer's environment.
(I posted to Intel Premier Support earlier, but IPS replied that they recommended posting to the Edge Software Hub Communities.)
Miura/OEC
JesusE_Intel
Hi Chinatsu_Miura,
Thanks for reaching out. Do you know if the customer's system meets the system requirements as listed in https://eci.intel.com/docs/3.0.2/getstarted/requirements.html? You mentioned, this is only observed on the customer's system which is a laptop, do you have a laptop with similar specs to test?
Jesus
JesusE_Intel
Hi Chinatsu_Miura,
Jesus
JesusE_Intel
