Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
When I try to install EII 2.4,it is occur an error.
chinafeifei93831
The error is just like below. I wanna know what reason causes this error.
Murni_J_Intel
Do you mean the latest EIIv2.3 ? May I know if you are running behind proxy? if yes, you will need to setup the proxy configuration accordingly in /etc/environment. after done, reboot the system and try to run the installation again.
chinafeifei93831
Thanks for your reply . But I did not use any proxy . I just install EII in the Wired network and it is occur the error.
Murni_J_Intel
did your wired network is not running behind proxy? May I know if you encounter this during your first installation or you have tried before?
chinafeifei93831
It is occured during my first installtion.I only install it in Wired Network. I never configure a proxy before. Do you mean that I also have to get a proxy when I connect the Wired Network?
Murni_J_Intel
The wired network also possible to run behind proxy configuration. It will be best if you can help to confirm that first before proceeding with the installation.
Murni_J_Intel
Hi @chinafeifei93831
I already work with you offline for this and the issue is related to internal testing. For your information, we only supported the PV release package through this forum.
