Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
igh ethercat install location issue
nxlou94
I setup ECI apt repo, installed linux-intel-rt and ighethercat, things work, but headers seem to be in wrong location, and lib symlink seems to be missing. It looks like the installation didn't finish correctly. I do see an error during my installation, but I don't know if it is related.
headers are located in: /usr/src/ighethercat-dkms-1.5.2/include/ , this seem to be a source code location (which I have to add to header file search path, and Makefile template doesn't mention this location at all)
gf@gf-cst-i5-2:/$ sudo find -name ecrt.h
./usr/src/ighethercat-dkms-1.5.2/include/ecrt.h
libs are located in: /usr/lib/x86_64-linux-gnu/, but no symlink with name libethercat.so exist, so I had to create that for my linker to be able to find the library.
gf@gf-cst-i5-2:/$ sudo find -name libethercat.*
./usr/lib/x86_64-linux-gnu/libethercat.so.1.0.0
I see this during my installation:
gf@gf-cst-i5-2:~$ sudo apt install ighethercat ighethercat-dkms ighethercat-examples ecat-enablekit
depmod...
Building initial module for 6.5.0-27-generic
Error! The /var/lib/dkms/ighethercat-dkms/1.5.2/6.5.0-27-generic/x86_64/dkms.con
f for module ighethercat-dkms includes a BUILD_EXCLUSIVE directive which does no
t match this kernel/arch/config.
This indicates that it should not be built.
Skipped.
I setup ECI apt repo, installed eci-customization, linux-intel-rt and ighethercat following these pages:
https://eci.intel.com/docs/3.2/getstarted/apt_instructions.html
https://eci.intel.com/docs/3.2/getstarted/installing_packages.html
https://eci.intel.com/docs/3.2/components/ethercat.html
my bash history:
gf@gf-cst-i5-2:~$ history
1 sudo -E wget -O- https://eci.intel.com/repos/gpg-keys/GPG-PUB-KEY-INTEL-ECI.gpg | sudo tee /usr/share/keyrings/eci-archive-keyring.gpg > /dev/null
2 echo "deb [signed-by=/usr/share/keyrings/eci-archive-keyring.gpg] https://eci.intel.com/repos/$(source /etc/os-release && echo $VERSION_CODENAME) isar main" | sudo tee /etc/apt/sources.list.d/eci.list
3 echo "deb-src [signed-by=/usr/share/keyrings/eci-archive-keyring.gpg] https://eci.intel.com/repos/$(source /etc/os-release && echo $VERSION_CODENAME) isar main" | sudo tee -a /etc/apt/sources.list.d/eci.list
4 sudo bash -c 'echo -e "Package: *\nPin: origin eci.intel.com\nPin-Priority: 1000" > /etc/apt/preferences.d/isar'
5 sudo bash -c 'echo -e "\nPackage: libflann*\nPin: version 1.19.*\nPin-Priority: -1\n\nPackage: flann*\nPin: version 1.19.*\nPin-Priority: -1" >> /etc/apt/preferences.d/isar'
6 sudo apt update
7 sudo apt install -y eci-customizations
8 sudo apt-get reinstall '(firmware-linux-nonfree|linux-firmware$)'
9 sudo apt install -y linux-intel-rt
10 sudo reboot
11 uname -a
33 sudo apt install ighethercat ighethercat-dkms ighethercat-examples ecat-enablekit
34 history
my active kernel after installing eci-customizations and linux-intel-rt, and reboot:
gf@gf-cst-i5-2:~/ws/web-backend$ uname -a
Linux gf-cst-i5-2 5.15.129-rt67-intel-ese-standard-lts-rt+ #1 SMP PREEMPT_RT Fri Mar 29 22:51:07 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
Iffa_Intel
could you share the error that you encountered when installing too (which you mentioned)?
Perhaps this is related to your network, did you try to re-install using a different network?
Cordially,
Iffa
Iffa_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
