Edge Software Catalog
483 Discussions
tranining stops automatically in tls web ui
vkherde
Hi Team,
I am trying to train a new model using tls docker deployment, however the training stop unexpectedly without throwing any errors. Sharing the screenshots for the same.
I am using EIS on a Virtual Machine which has specs of
RAM: 4GB, ROM: 64GB
WengWai_C_Intel
Hi @vkherde ,
For deep learning model training, it is recommended to use 32GB RAM system or above. With 4GB of RAM, most likely will hit into memory resources issue. While the deep learning model training process is running, you can use steps below to look at the log.
1) Use command 'docker ps' to list the active containers are running.
2) You should see 'dlscore' container is running. Use command 'docker logs -f dlscore' to look at the log while the model training is running.
In addition, it is also recommended to use a native system instead of VM for deep learning model training to reduce overheads from VM. Feel free to try the above suggestion and feedback to us. Thanks!
WengWai_C_Intel
Hi @vkherde ,
