Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
xenomai ethercat ec_generic not run
junjuns
xenomai ethercat not ec_generic.ko eci-user@eci-intel-24f9:/usr/src$ uname -a Linux eci-intel-24f9 5.15.129-intel-ese-standard-lts-dovetail+ #1 SMP PREEMPT IRQPIPE Tue Apr 16 09:42:19 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux e10001e not PACKAGE_NAME="ighethercat-dkms" PACKAGE_VERSION="1.5.2" BUILD_EXCLUSIVE_KERNEL="^((5\.(1[05])\.)|(6\.1\.))" CLEAN="make -C ${kernel_source_dir} M=${dkms_tree}/ighethercat-dkms/${PACKAGE_VERSION}/build clean" BUILT_MODULE_NAME[0]="ec_master" BUILT_MODULE_LOCATION[0]="master" DEST_MODULE_LOCATION[0]="/updates/dkms" BUILT_MODULE_NAME[1]="ec_igb" BUILT_MODULE_LOCATION[1]="devices/igb" DEST_MODULE_LOCATION[1]="/updates/dkms" BUILT_MODULE_NAME[2]="ec_igc" BUILT_MODULE_LOCATION[2]="devices/igc" DEST_MODULE_LOCATION[2]="/updates/dkms" BUILT_MODULE_NAME[3]="ec_dwmac_intel" BUILT_MODULE_LOCATION[3]="devices/stmmac" DEST_MODULE_LOCATION[3]="/updates/dkms" MAKE[0]="./configure --with-devices=8 --enable-kernel --with-linux-dir=${kernel_source_dir} --disable-eoe --enable-sii-assign --enable-hrtimer --enable-cycles --enable-igb --enable-igc --enable-stmmac --enable-generic --disable-8139too --disable-r8169 --disable-e100 --disable-e1000 --disable-e1000e --disable-tool --disable-userlib && make -C ${kernel_source_dir} modules M=${dkms_tree}/ighethercat-dkms/${PACKAGE_VERSION}/build" MAKE_MATCH[1]="dovetail" MAKE[1]="./configure --with-devices=8 --enable-kernel --with-linux-dir=${kernel_source_dir} --disable-eoe --enable-sii-assign --enable-hrtimer --enable-cycles --enable-igb --enable-igc --enable-stmmac --enable-generic --disable-8139too --disable-r8169 --disable-e100 --disable-e1000 --disable-e1000e --disable-tool --disable-userlib --enable-rtdm && make -C ${kernel_source_dir} modules M=${dkms_tree}/ighethercat-dkms/${PACKAGE_VERSION}/build" AUTOINSTALL="yes"
Iffa_Intel
In order for us to replicate this issue, could you:
  1. elaborate further your issue
  2. which ECI Ethercat guide or sample are you using
Cordially,
Iffa
junjuns
eci 3.2 xenomai system
ethercat xenomai .
ko file not ec_generic.ko
Iffa_Intel
This ECI guide/sample is specific for ECI Xenomai and EtherCAT use case: Intel® Edge Controls forIndustrial (Intel® ECI) - Motion Control on Xenomai EtherCAT*
It seems that your Xenomai has been correctly validated:
Perhaps you need to check and validate your EtherCAT installation and its setup.
You may refer to the guide I mentioned above for this purpose.
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
