Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
918 Discussions
Backplane communication with I210 IS
MGlas
Hello together,
I want to realize a backplane communication with two I210 IS Ethernet controller. My intention is to use SGMII or SERDES interface.
Is there an application note available how to realize such an application?
I have to realize a communication of two processors via. Ethernet. The whole system is designed on only one circuit card. From upper software point of view the system should react like two separated processor systems which are connected via LAN cable. I tried to show it in a small sketch below.
Thanks in advance,
Maximilian
CarlosAM_INTEL
Hello, GlaserMaximilian :
The information that may help you is stated in section 1.6.2, on page 41 of the https://cdrd.intel.com/v1/dl/getContent/543838.htm Intel Ethernet Controller I210 [Springville] Gigabit Ethernet Controller External Architecture Specification [EAS] document # 543838, which is accessible when you are logged into your EDC privileged account.
We hope that this information may help you.
Carlos_A.
MGlas
HI Carlos,
thanks a lot for your answer. Unfortunately I can´t open the link you inserted. Also when I serach for the docuemnt number I do not find any document. Could you please help me to find this document. Thanks a lot in advance.
Best regards
Maximilian
CarlosAM_INTEL
Hello, GlaserMaximilian:
Thanks for your reply.
You are correct, this document is accessible when you use a Privileged Resource & Design Center (RDC) account instead of the mentioned EDC at:
This account can be requested by filling out the form stated at the following website:
https://www-ssl.intel.com/content/www/us/en/forms/design/contact-support.html
Carlos_A.
