Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
940 Discussions
Compliance Test with I210-IS SFP+SFI 10GSFP_Cu
haidar007
Hi Everyone
I want to run complicance with I210-IS
Is there any available information? I can't find details in the datasheet, such as creating an SFP Test Pattern.
I need run various test based on following test pattern:
Test pattern 8180
Test pattern PRBS9
Test pattern PRBS31
Any information would be appreciated.
Thanks for your help.
Haidar
Diego_INTEL
Hello @haidar007,
The LANConf from document #348742 can used for IEEE testing. I looked internally but it seems we don't have a tool for SFP Test patterns.
The LANConf User Guide can be found in the DOCS directory.
Also, you may check the following documents:
#617297 - 1000BASE-T/100BASE-TX/10BASE-T Physical Layer Compliance Tests Manual
#824694 - Intel Ethernet Conformance Test
@Diego_INTEL
