Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
943 Discussions
EEPROM Access Tool for ARM (Intel I226)
AxitSoni
Hello Intel Team,
We are having Intel I226 Ethernet Phy Controller connected with Embedded Platform which is QCOM ARM based SOC connected over PCIE Interface.
We need EEPROM Access Tool for Flashing and its Usage Guide.
We are using the Linux Kernel Driver (igc.ko). But its causing the ERROR.
igc 0001:01:00.0: The NVM Checksum Is Not Valid
 Code:
         if (igc_get_flash_presence_i225(hw)) {
              if (hw->nvm.ops.validate(hw) < 0) {
                      dev_err(&pdev->dev, "The NVM Checksum Is Not Valid\n");
                      err = -EIO;
                      goto err_eeprom;
Please help us with the EEPROM Access Tool and Its Flashing Guide.
Ragulan_Intel
Hello AxitSoni,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns.
Therefore, I will be moving this discussion to our Embedded Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Ragulan_Intel
Intel Customer Support
AxitSoni
Thank you.
Looking forward to get required support from Intel Team on above concern.
Diego_INTEL
Hello @AxitSoni,
You can check the following documents from RDC:
#572162 -  EEPROM Access Tool [EAT]
#634290 - EEPROM Access Tool User’s Guide
You will need a Premier account in order to get access to these documents.
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
@Diego_INTEL
AxitSoni
Hello @Diego_INTEL ,
I got the RDC access. I downloaded the EEPROM Access Tool. But when executing the NIC dump command. I see no NIC present for Intel I226 Chipset. Please check below snippet.
/data/eepromaccesstool-0.8.0 # ./EepromAccessTool
Intel(R) EEPROM Access Tool NVM/OTP Programming Example Tool   Version 0.8.0
Provided under the terms of a CNDA.  Do Not Distribute.
Copyright(C) 2017-2020 by Intel(R) Corporation
NIC     BUS     DEV     FUN     Silicon Memory Type Present
 Can you please guide whether and how we can use this EepromAccessTool with Intel I226 Ethernet Controller ?
Axit Soni
Diego_INTEL
Hello @AxitSoni,
My apologies for the delay, also I forgot to mention the following:
The i225 and i226 are not supported for ARM, but it is possible to use the EEPROM Access Tool with the i226 by adding the device IDs mentioned in the datasheet, document #596659, in section 5.1.1.8 Device ID - 0x000D.
https://cdrdv2.intel.com/v1/dl/getContent/596659
Please check this post, the user Andy helped a lot by sharing their patch, so you can check the implementation.
https://community.intel.com/t5/Embedded-Connectivity/EepromAccessTool-for-i226/m-p/1574989
@Diego_INTEL
GB10
I was looking for a way to configure the flash and MAC address of an i226 on an ARM CPU. You mentioned adding a device ID; could you please explain in detail which parts of eepromaccesstool I need to modify and how I need to run `make`?
