Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
EEUPDATE and LANConf Guide
ECama1
Hi Intel Embedded Community:
We will use the tools EEUPDATE and LANConf (from the Quartzville tools package) for programming the MAC in a i211. Could you please provide us the usage guide for this tools, please? To mailto:[email protected] [email protected] and mailto:[email protected] [email protected].
Also, it was installed the software in windows 64, but when i run the application EEUPDATEw64e.exe (in administrator mode) is just flicker the window. How can i open the application correctly?
Thanks in advance.
Adolfo_S_Intel
Hello, Eulises
The documentation of these tools come included on the Quartzville tools, to access them, you can go to the Intel RDC and find it with document number: 348742.
Here you can find information about how to access the RDC:
I hope this information is useful for your case.
Adolfo Sanchez
ECama1
Thank you Adolfo:
But I have another situation. I was installed the software in "Microsoft Windows", but when I run the application EEUPDATEw64e.exe (in administrator mode) It is just flicker the window and not open the application. I followed the steps for the installation but I do not know if I am omitting any steps to open the application correctly. There is something that can cause this issue?.
Adolfo_S_Intel
Hello, Eulises
Please provide the following information:
1) What Windows version are you using?
2) What Intel Ethernet Controller are you using?
3) Does the issue occurs only on your board or does the issue occurs on any System running Intel Processors? If you have not done this, please test it.
Adolfo Sanchez
JLi19
Hi AdolfoS,
Is it possible to give a link to this document with number 348742? I can not find this document when searching this number, or "Quartzville" as keyword.
CarlosAM_INTEL
Hello, bigben:
The https://cdrdv2.intel.com/v1/dl/getContent/348742 Intel(R) Network Connections Tools 23.2 PV LAN Software Tools document # 348742 is accessible when you are logged into your Resource & Design Center (RDC) privileged account.
It can be requested by filling out the https://www.intel.com/content/www/us/en/forms/design/contact-support.html RDC Account Support form.
We hope that this information may help you.
Carlos_A.
JLi19
Hi Carlos_A,
Thank you! I sent the form now
