Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
EEUpdate.exe
grigol_gkl
Please help with link to download EEUpdate.exe
Thank you!
Jaime_Lizarme
Hi @grigol_gkl
Thank you for contacting the Intel Embedded Community.
Sure, you can get EEUpdate from Intel RDC kit 348742 (Quartzville)
https://cdrdv2.intel.com/v1/dl/getContent/348742?wapkw=eeupdate
In order to access RDC documents, please go through the following instructions described on the below article.
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
Jaime L.
lostair
False information supplied, I have tried this solution instructions and it doesn't work. Raised a ticket with Intel support, hopefully can get something done about this Intel fault.
lostair
Problem sorted, got chatgpt to write a exe binary to do the job. Used rufus to create a FreeDOS USB pendrive then pasted the binary file in the drive. Booted and done.
grigol_gkl
I went through some registration process but still can't get the kit 348742 you mentioned.
Looks very complicated
