Hi all,
We are trying to use flow-director to split data traffic to a VF in NIC X540-AT2 and we have successfully experimented this solution with packet ( MTU < 1500 ) . But with packet that bigger than MTU 1500 ( IP fragmentation breaks packets into smaller fragments ) , Flow Director doesn't work !!!!!
- Create VFs
#echo 1 > /sys/class/net/p7p2/device/sriov_numvfs
- Config Flow Director ( for queue_id 0 of VF 1 ) :
#ethool --config-ntuple p7p2 flow-type udp4 dst-ip 192.168.1.5 dst-port 2152 action 4294967296 (
action = vf_id * 2^32 + queue_id )
Filter: 2045
Rule Type: UDP over IPv4
Src IP addr: 0.0.0.0 mask: 255.255.255.255
Dest IP addr: 192.168.1.5 mask: 0.0.0.0
TOS: 0x0 mask: 0xff
Src port: 0 mask: 0xffff
Dest port: 2152 mask: 0x0
Action: Direct to queue 4294967296
- OS : CentOS 7
We also change flow-type udp4 into ip4 , but it still doesn't work.
Could anyone give me some suggestions to solve it ??
Brgs,
thanhnv118
链接已复制
Hello thanhnv118,
For us to further check the issue, please tell us why are you doing this experiment? Are you designing a system with embedded X540-AT2?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel Customer Support Technicians
Dear Michael,
Thank you for your reply,
I'm trying to split traffic between Linux user space and kernel space, so i use Flow Bifurcation mechanism as a guide :
https://doc.dpdk.org/guides-17.05/howto/flow_bifurcation.html .
And my issue : with fragmented packets , VF doesn't have any packet .
thanhnv118
Hello thanhnv118,
For us to understand what you are doing and to route you to the right support if needed. Please clarify if you are designing a system to a software?
Michael L.
Hi Michael,
Yep, I have a process (at server A ) send UDP packet size ( MTU > 1500) to card NIC 540-AT2( at server B).
I want to filter this packet with Flow director and I use tcpdump in VF but do not have any packets.
My question is very simple : How to filter fragmented packet with using Flow Director?
Brgs,
thanhnv118
Dear Mr Michael,
Thank you for your support,
I hope you give me solution as soon as possible.
Brgs,
thanhnv118
Hello, @thanhnv118:
Thank you for contacting Intel Embedded Comunity.
You should address your VF consultation as a reference to the channel listed on the following website:
Hi CarlosAM,
Thank you for your support.
So i have a question : Does Intel Ethernet Flow director support fragmented packet filtering ???
Bgrs,
thanhnv118
Hello, @thanhnv118:
Thanks for your reply.
Based on your last communication, we suggest following the suggestion stated in our previous message, which is the proper way to answer this type of question.
