Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
943 Discussions
How to flash I210 iNVM on ARM platform
Ricodeng
Hi:
  Our platform base on ARM,integrated the i210 on the board, now we use Eepromaccesstool flash the iNVM,use below command:
EepromAccessTool -NIC=1 -f=I210_Invm_Copper_NoAPM_v0.6.HEX
but will report below error
[ 3.544557] igb 0000:01:00.0: Invalid MAC Address
[ 3.554800] igb: probe of 0000:01:00.0 failed with error -5
could you help check this
thanks
CarlosAM_INTEL
Hello, @Ricodeng:
Could you please clarify if your post in this thread is related to your question in the following forum?
https://community.intel.com/t5/Embedded-Connectivity/How-to-flash-mac-address-in-NVRAM-of-i210-WGI210ITSLJXS/m-p/1198985#M2464
We are waiting for your clarification.
@CarlosAM_INTEL.
Ricodeng
Hi Carlos:
    We have RDC account and checked  EEUpdate and LanConf tools, its for X86 platform tool, we use Qualcomm platform + linux OS, have to use  Eepromaccesstool flash the iNVM, please help check it again, thanks
CarlosAM_INTEL
Hello, @Ricodeng:
Thanks for your clarification.
We sent an email to the address associated with your account of this forum with suggestions that may help you.
@CarlosAM_INTEL.
Ricodeng
Hi Carlos:
     thanks for you reply,
Has got your email, but its for external spi flash,we need flash iNVM , we have got the EEPROMAccesstool,
want to know, what kinds of file need to flash in .HEX or .TXT? how can I change the MAC address?
thanks again
CarlosAM_INTEL
Hello, @Ricodeng:
Thanks for your reply.
You can find the information that may help you in the answer to questions 2.14, 2.15, and 2.25, on pages 8, and 9 of the Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions [FAQs] document # 335346. You can find it when you are logged into your Resource & Design Center (RDC) privileged account on the following website:
https://cdrdv2.intel.com/v1/dl/getContent/335346
You should fill out the RDC Account Support form to process your account update request or report any inconveniences with the provided site. You can be found on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
Ricodeng
Hi Carlos:
     has check this, no help for my issue, our board base on ARM,has flashed the iNVM with Eepromaccesstool, but cant get the MAC address under the OS, thanks
Ricodeng
hi CarlosAM_INTEL:
      we use i210 AT on android 11 Qualcomm 845 platfrom, kernel verion 4.9 , use EepromAccessTool -NIC=1 -f=I210_Invm_Copper_NoAPM_v0.6.HEX to flash firmware, then get device id 0x157b.  but when driver probe can not get right mac address, the all mac address is zero. The firmware && codes are all uploaded, please help to check why this issue occurred?  If possible, I can upload the codes.
the firmware contains below numerical value
16E80002 00001541 038D0002 0B403C21 402F1411 34003611 1C605011 157B1A11
05844211 02804811 73431E19 0000001A 08100241 16D10002 00FF00A8 16D00002
5E000090
TKS!
CarlosAM_INTEL
Hello, @Ricodeng:
We sent an email to address related to your account of this forum to give the suggestions that may help you.
@CarlosAM_INTEL.
Ricodeng
hi  CarlosAM_INTEL:
      Here is our firmware HEX file, could you point out which bits are mac address?
5E000090
TKS!
CarlosAM_INTEL
Hello, @Ricodeng:
We suggest following our suggestion stated in the email sent to you to find the answer to your last communication as well.
@CarlosAM_INTEL.
