Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
939 Discussions
I have an Intel i210 designed into an embedded application and have prototypes in hand
DINO_L_Intel
The EDC had a question from a customer, Chris, that I'd like to post on his behalf: I have an Intel i210 designed into an embedded application and have prototypes in hand. The design is based on the reference design for that device. I can see it on the PCIe bus (lspic in Linux) and I can check it with the nvmcheck utility (MAC address is all 0's). The problem is that I cannot find the necessary software app to program the device and set up the MAC address. Is there something in the preboot or proadmin packages that allow me to do this? Do you have an appnote for programming the device?
WILLIAM_C_Intel
Hi Dino, I have seen Chris's case, and am trying to find correct answer for him.
William
Natalie_Z_Intel
Hello - I will close this thread out as it is continued on /thread/7294 http://embedded.communities.intel.com/thread/7294.
