Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
918 Discussions
I need help with WGI210IT Ethernet control for use.
ohsujin
We developed a new embedded board by adding a WGI210IT Ethernet controller using PCI communication to the CPU module (cona-sa5) using Intel E3950.
When I installed Windows 10 IoT and ran and checked the Device Manager, the Ethernet controller was recognized on the PCI port.
However, the driver installation does not proceed.
After running the Terminal Program to check the status of the Ethernet device provided by Intel, the MAC Address information is set to '0'.
After searching the Intel community, we believe that Flash memory program updates are needed.
Please give me a solution to solve the problem.
Diego_INTEL
Hello @ohsujin,
You need to use the document #348742 - Intel® Network Connections Tools 28.2 PV LAN Software Tools from RDC and the document #513655 - Intel® Ethernet Controller I210 and I211- AT Production NVM Images.
You will need a Premier account in order to get access to the documents.
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
@Diego_INTEL
