Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
I210-AT NC pin function
Neil3
I am looking at using the WGI210-AT ethernet controller for a new design. Pin 22 is called NC, which I had assumed was for No Connect. However, table 2-8 in the datasheet gives this an optional function 'Optional pin used to connect an external power supply to the PCIe block in order to replace the internal LDO'. The reference schematic appears to leave this pin unconnected,  but I wanted to confirm the operation. Does it have an internal PU/PD to enable the internal LDO? It is not listed in the PU/PD table 2-1. Thank you.
CarlosAM_INTEL
Hello, @Neil3:
You need to update your profile to the premier option to help you. You should fill out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/developer/premier-registration.html
You should use a business email address to evade any inconvenience. Please avoid the free email provider's address (such as the one provided by Hotmail, Gmail, Yahoo, or others).
@CarlosAM_INTEL.
Neil3
Hi, I already have updated to a premier account, but it hasn't linked my previous post to the updated account.
CarlosAM_INTEL
Hello, @Neil3:
Thanks for your reply.
We sent an email to the address related to this account with information that may help you.
On the other hand, your account inconveniences should be supported using the form provided in our previous communication through this forum.
@CarlosAM_INTEL .
