Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
957 Discussions
I210 MAC address programming issue
AWang31
hi,
Recently I met a curious issue about I210 MAC address programming.
The EEPROM image is offline programmed with default MAC address (00:A0:C9:00:00:00).
And the MAC address can be changed only once online with eeupdate64e.efi tool.
I want to know where is the problem. Does anyone meet?
AWang31
hi Carlos_A,
Thanks a lot for your hint, while I'm still confused.
I use I210 with an external flash memory. And after I update the MAC address, I'll power down and power on the product.
For the pin12 the document mentioned, I tried the pull-up or pull-down scheme.
I can't figure out why the MAC address can only be changed once. Certainly, after reprograming the flash offline, the MAC address can be changed once online again.
CarlosAM_INTEL
Hello, erichh:
The information that may help you is the answers to the questions 2.25 and 2.23, on page 9 of the https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions (FAQs) document # 335346.
We hope that this information may help you.
Carlos_A.
AWang31
hi Carlos_A,
