Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
I225V network card problem
ou
we have developed a custom board using the i225-IT Ethernet controller.
We encountered the following problems:
1. In the process of using I225V, only 500M network bandwidth is accepted;
2. Receive and send simultaneously, with network bandwidth of 800M;
3. When sending only, it is 1000M;
CarlosAM_INTEL
Hello, @ou:
We need to address the following questions to understand your consultation:
Could you please clarify if your question is related to the Intel® Ethernet Controller I225-IT or the Intel® Ethernet Controller I225-V?
What is the list of documents that you used to develop your custom board using the Intel® Ethernet Controller?
We are waiting for your answer.
@CarlosAM_INTEL.
ou
使用的KIT-I225-IT,也使用过KIT-I225-V,这两个BGA是一样的。都存在接收带宽500M现象。
CarlosAM_INTEL
Hello, @ou:
Thanks for your reply.
We only provided support in the English language.
It seems that you do not understand our second question, please let us paraphrase it.
What are the documents that you are using to design your custom board with the Intel® Ethernet Controllers I225-IT and I225-V? By the way, what is the procedure that you have followed to obtain these documents?
Also, is this forum related to the following created by you?
https://community.intel.com/t5/Embedded-Connectivity/Flash-I225-firmware/m-p/1465901#M4366
@CarlosAM_INTEL.
