Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
930 Discussions
Intel Bluemoon PMB-8763 and Bluetooth vulnerabilities
rvuyy
This is regarding the vulnerability: CVE-2018-5383 identified recently.
It is understood that the above vulnerability affect all devices with Bluetooth SSP and LE secure connections implementations.
In those lines, we wanted to check if the modules "PMB 8753, PMB 8763, UniStone PBA 31308" which are being used in our solutions are affected.
Can we know your plan in supporting us resolving the vulnerability if existed?
References:
https://www.kb.cert.org/vuls/id/304725 https://www.kb.cert.org/vuls/id/304725
https://securityboulevard.com/2018/07/cve-2018-5383-bluetooth-vulnerability-impacts-apple-intel/ https://securityboulevard.com/2018/07/cve-2018-5383-bluetooth-vulnerability-impacts-apple-intel/
Thanks and Regards,
Ravi Teja
CarlosAM_INTEL
Hello, ravitejav:
Your consultation should be addressed to the support channel listed at the "Need product support?" section of the following website:
https://www.intel.com/content/www/us/en/security-center/advisory/intel-sa-00128.html https://www.intel.com/content/www/us/en/security-center/advisory/intel-sa-00128.html
We hope that this information may help you.
Carlos_A.
