Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
918 Discussions
Intel® Ethernet Server Adapter I340-F4, Fiber, EEPROM image
Andrew3
looking for working EEPROM image Quad Fiber.
in FAQ document 82580eb-82580db-gbe-lan-controller-faq.pdf, page 9:
27. Can the latest EEPROM images be used on A0 silicon?
No. A0 and A1 EEPROM images are not interchangeable with A0 and A1 Silicon. A0 silicon requires A0 images and A1 silicon requires A1 images.
A0 images are no longer available.A1 images can be found in CDI/IDL at:
Intel® 82580 Gigabit Ethernet Controller – EEPROM Images – Rev. 3.29 (link to http://www.intel.com/cd/edesign/library/asmo-na/eng/441658.htm  is not work)
An NDA is required to access this information.
Mike_Intel
Hello Andrew3,
Before we proceed, let me check. Are you designing a system with embedded I340-F4?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 2 workings days. Thank you.
Michael L.
Intel Customer Support Technicians
Andrew3
Yes, processor and network controllers will be on one board and in one case.
Mike_Intel
Hello Andrew3,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Michael L.
CarlosAM_INTEL
Hello, @Andrew3:
You can find the  Intel® 82580 Gigabit Ethernet Controller EEPROM Images document # 441658 on the following website when you are using your Resource & Design Center (RDC) privileged account :
You should fill out the RDC Account Support form to process your account update request or report any inconveniences with the provided site. You can be found on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
We suggest you use a business email address to evade any inconvenience. Please avoid the free email provider's address (such as the provided by Hotmail, Gmail, Yahoo, or others).
@CarlosAM_INTEL.
