Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
941 Discussions
Intel I350-AM2 EEPROM config
DUCUY
Hello All,
I'm developing Network adapter using I350-AM2 controllers. This adapter will support 1  RJ45 ports on MDI_0 and 1 SFP port on SFP_0.
Right now we only saw the SFP port already came up and working, but RJ45 port not come up yet. Is it firmware in EEPROM issue? Do we have any firmware to enable this features?
Uy
DUCUY
Updated:
After program EEPROM image I350_2Copper2SerdesFiber_NO-MNG_1_63. then RJ45 worked but SFP notwork anymore. Do we have any ways to config both Copper and Fiber work at the same time?
Here is lspci output:
02:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
02:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
and here is ethtool:
# ethtool enp2s0f0
Settings for enp2s0f0:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: on
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
MDI-X: on (auto)
Supports Wake-on: pumbg
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
DUCUY
Another Question:
In EEPROM release notes, i saw that:
I350_2Copper2SerdesFiber_NO-MNG_1_63:
This package is for the 17x17 pin I350 with 2 ports to be configured for a 1000BASE-T (Copper) connection and 2 ports to be configured for a SerDes Fiber connection. No manageability enabled.
When used this firmware for I350-AM2, is it become 1 port for Copper and 1 port for Fiber? right now using this firmware just only Copper port work.
Uy
DUCUY
It seem i posed in the wrong forum, it should be in  Embedded Connectivity.
Anyone can help to move this topic to the right place?
Uy
Sreelakshmi1
Hi DUCUY,
Greetings!
Thank you for posting in Intel community forum!
Apologies for the delay in response regarding this matter.
Kindly confirm whether the reported issue is resolved or if you need further assistance.
Meanwhile, we will move the request to the Intel Embedded Connectivity Forum for the reported issue, and you will receive a response from the respective team shortly.
Sreelakshmi
Diego_INTEL
Hello @DUCUY,
I will not transfer this forum back but all Ethernet related forums should be in the Ethernet community, my apologies for the confusion.
I have been investigating regarding your issue, it could be the design may have something missing, I think you can use the checklist for the i350 first, also, I read that LAN1 and LAN 2 can connect to RJ45 and LAN 3 and LAN 4 connect to SFP.
#597705 - Intel Ethernet Controller I350-A [Powerville] Schematic and Layout Design Checklists
#452398 - Intel® Ethernet Controller 82580 I350 [Powerville] – Pin Compatibility Guide
Also, I think it may be best to use the Premier support to get better support regarding this design.
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
@Diego_INTEL
DUCUY
Thanks Diego for really Value response, Appreciated.
For I350-AM2, it only have 2 ports, so i routed the Port0 to RJ45 and Port1 to SFP. but unfortunately don't have any available firmware for EEPROM support it. do we have any resoure that can help me to develop firmware for it?
I will try to reach with Premier support, and also looking for help from here.
Thank for help
Uy
