Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
957 Discussions
Intel I350 controller TSN (Time sensitive networking)
Balajisesha
Does Intel I350 controller supports TSN standards such as IEEE802.1AS and IEEE 802.1Qbv?
Caguicla_Intel
Hello Govind,
For us to proceed checking your request, kindly provide the following information.
1. Operating System that you intend to use.
2. Is the i350 embedded on the motherboard? If yes, please share the brand and model of the board. If no, kindly provide the PBA of the adapter. You may refer to the link below on where to find the PBA number. It consist of 6-3 digit number located at the last part of the serial number. This would help us identify if you are using an Original Equipment Manufacturer(OEM) or retail version of Intel Ethernet Adapter.
Identify Your Intel® Network Adapter Model Using PBA Number
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-i-o/ethernet-products.html
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel® Customer Support
Balajisesha
Hello Crisselle,
1. Operating system is Linux.
2. We are planning to make own board with Intel I350-AM4 chip.
Hope to hear from you soon.
M.J.K.Govind.
Mike_Intel
Hello Govind,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Michael L.
CarlosAM_INTEL
Hello, @Balajisesha:
We want to address the following questions to understand your request:
Could you please let us know if your request is related to a technical question? In case that your answer is affirmative, could you please let us know a detailed description of the problem?
We are waiting for your answer to these questions.
@CarlosAM_INTEL.
Balajisesha
Hi Carlos,
Request is basically a technical question.
Intel I210 controller supports TSN(Time sensitive networking) standards.
M.J.K.Govind.
CarlosAM_INTEL
Thanks for your clarification.
We have sent an email to the address associated with this account with information that may help you.
@CarlosAM_INTEL.
Laya1
So does it? I also want to know about the same
Diego_INTEL
Hello @Laya1,
You can check the datasheet to know the Standards that are supported in the i350 controller.
https://www.intel.com/content/www/us/en/content-details/333171/intel-ethernet-controller-i350-datasheet.html?wapkw=i350%20standards&DocID=333171
For example:
@Diego_INTEL
