Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
950 Discussions
Intel RealSense D410 USB Disconnect
Gururaja
We have connected two D410 camera sensor with Raspberry Pi 4 model B for video capture. we are using 0.5m USB cable (Type A to Type C) for first camera and 5m USB cable (Type A to Type C) for second camera.  Initially devices are working properly for day or two. Later camera module is abruptly disconnected on its own.
If we replug the power then device will work properly. same disconnection issue will arise after few hours /days of operation.
I am looking for support to address USB disconnection issue
K.Gururaja
AlHill
You may get a better response here:
https://support.intelrealsense.com/hc/en-us/community/topics?erpm_id=1234530_ts1600136184847
CarlosAM_INTEL
Hello, @Gururaja:
You should address your RealSense consultations as a reference through the channels mentioned on the following website:
On the other hand, you need to address your consultation of the mentioned third-party device, as a reference as well, using the channels listed on the following website:
https://forums.raspberrypi.com/
@CarlosAM_INTEL.
