Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
955 Discussions
Intel i210 eeprom tool for ARM
Xueyangz
We're using a i210 ethernet controller with an RK3568 CPU (ARM).
We encountered the following error message when using lspci:
0002:21:00.0 Ethernet controller: Intel Corporation I210 Gigabit Unprogrammed (rev 03)
When we replacing it with another controller that includes a mac address,it restored normal functionality.
Therefore, we sincerely hope that the technical team can provide eeprom tool for us to configure the MAC address of the chip on this ARM platform.
Many thanks for your help.
Xueyang Zhang
Diego_INTEL
Hello @Xueyangz,
You can check in RDC for document #572162 - EEPROM Access Tool [EAT].
You will need a Premier account in order to get access to the documents I have mentioned, please check the following link in case you need help to create a Premier account.
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
@Diego_INTEL
Xueyangz
hello
Upon accessing the link you provided, I encountered the prompt said " I was already enrolled to Developer Zone Standard program".
May I confirm whether this indicates that I already hold the necessary license qualification as mentioned?
If so, I would appreciate your guidance on the subsequent steps.
Thank you for your support.
Diego_INTEL
