Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
943 Discussions
Interface Wireless Current Sensor with best MCU creating private as well as internet network
SCale1
Hello, I am using https://store.ncd.io/product/wireless-ac-current-monitor/http:// Wireless Current sensor which creates the sensor network and sends the data from sensor transmitters to its receivers which can further connected with PCs or laptop. But I want to send the data readings to the online server database called firebase and doing this I am looking for some good MCU which will consume less power and uses great accuracy and good compatibility with huge industrial sensor networks. Any suggestion to make this kind of solution work with good MCUs will be very helpful.
CarlosAM_INTEL
Hello, Bane :
In order to be on the same page, could you please confirm if this thread is related to Carlos_A.
