Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
957 Discussions
Memory copy using Intel QuickData Technology on Intel Xeon D-1746ter
heleboy
Dear,
For a custom board with Intel Xeon D-1746ter, I am developing a DMA based application making transaction to/from FPGA board memory on Windows 10/11. After some investigation, I found DMA capability of Intel Quickdata Technology. Now, I am looking for ways to use it to make memory copy from memory to memory. I checked the EDS documentation and found the registries of Crystal Beach successfully.
When I make further investigation, I ran into following link;
https://www.drvhub.net/devices/chipsets/intel/chipset-quickdata-technology-device-3430
I understood that there is already a Windows driver. I would like to understand how to use this driver in my application.
Could you please share/provide documents or samples on how to use the driver in my application?
Could you please recommend on how to proceed?
LK
CarlosAM_INTEL
Hello, @heleboy:
We suggest using the following websites that may help you:
https://www.intel.com/content/dam/doc/white-paper/quickdata-technology-software-guide-for-linux-paper.pdf
https://www.intel.com/content/www/us/en/architecture-and-technology/intel-quick-assist-technology-overview.html
You should also as a reference consider the information stated on the following website:
https://doc.dpdk.org/guides/dmadevs/index.html
@CarlosAM_INTEL.
heleboy
Dear Carlos,
Thank you for sharing links. I have also noticed the links. I think the links are related to Linux. Mine is in Windows. At first, it is better for me to find some ready solutions in Windows. I noticed the Windows driver below.
I think it is developed by Intel.
Can you please share documents on how to use it in my application? İoctl commands and parameters?Other Windows drivers? How to use it?
Best regards
Heleboy
CarlosAM_INTEL
Hello, @heleboy:
Thanks for your update.
The website that you mentioned is not the Intel one. Therefore,  we cannot assure you that this driver is from Intel.
You may find the drivers from Intel on the following website:
https://www.intel.com/content/www/us/en/download-center/home.html
Also, we suggest reviewing the information stated on the following website that may help you:
https://www.intel.com/content/www/us/en/developer/articles/technical/fast-memcpy-using-spdk-and-ioat-dma-engine.html
@CarlosAM_INTEL.
heleboy
Dear Carlos,
Thank you for clarification. I see. I'll check spdk link. I saw some sample codes. I hope I can integrate it with my Windows driver.
If I run into a problem or need help, where can I contact?
Best regards
Heleboy
