Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
946 Discussions
Please send me I225-IT Linux Driver
jimin
https://www.intel.co.kr/content/www/kr/ko/download/15084/intel-ethernet-adapter-complete-driver-pack.html?elq_cid=957096_ts1688346772543&erpm_id=6983325_ts1688346772543
There is no I225-IT Linux driver here
Please send me the tar file of the I225-IT Linux driver.
We will install Ubuntu-18.04 on the below PC.
Please refer to attached file.
Thank you.
Diego_INTEL
Hello @jimin,
It seems it includes the Windows version only (it should be in PRO2500), but checking the compatibility list for the igc driver, it seems that is not supported for Ubuntu's version 18.04.
https://www.intel.com/content/www/us/en/support/articles/000055236/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
Also, you may check this link for Linux drivers.
https://github.com/torvalds/linux/tree/master/drivers/net/ethernet/intel
@Diego_INTEL
jimin
Hello Diego
When I run make with the Github you gave me, the following message appears.
make: *** No targets. Stop.
What does this mean?
Please advise.
Thank you.
Jimin.
Diego_INTEL
Hello @jimin,
I shared with you the general link. Did you tried with igc?
https://github.com/torvalds/linux/tree/master/drivers/net/ethernet/intel/igc
@Diego_INTEL
jimin
Hello Diego
Yeah, but when I run make, I get the following message appears.
Please advise.
Thank you.
Jimin.
Diego_INTEL
Hello @jimin,
You may check this, but the error must be due that it is incompatible with the kernel of your Linux.
https://github.com/intel/intel-graphics-compiler/issues/87
@Diego_INTEL
