Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
941 Discussions
Programming WGI210IS S LJXX for 1000BASE-BX interface
rhoffmann477
We have designed an PICMG AMC.0 board with two i210IS devices. Each device as a SST25VF040B flash device attached to it. Each is connected on the PCIe side to a Raptor Lake CPU, and on the Ethernet side to an Ethernet switch though the backplane using 1000BASE-BX.
The devices are initially reported as "unprogrammed". I downloaded a whole set of tools from Intel web site to program the devices, and the process is rather confusing. Which tool do I need to program the devices from a Linux 6.11 system, and which firmware and configuration file do I need?
Thanks in advance!
Diego_INTEL
Hello @rhoffmann477,
i210 can be used with an NVM image, you can use EEUpdate and one image from the document #513655 according to your design. Please check the Handbook and FAQ documents too.
Please look for the following documents in RDC:
-EEUpdate and Lanconf tools. #348742 - Intel® Network Connections Tools 30.1 PV LAN Software Tools
-#572162 - EEPROM Access Tool [EAT].
-#513655 - Intel® Ethernet Controller I210 and I211- AT Production NVM Images.
-#602853 - Intel Ethernet Network Controller Handbook
-#335346 - Intel® Ethernet Controller I210/I211 - Frequently Asked Questions
2.25 Why does the I210 not work after EEUPDATE successfully programs the image?
When EEUPDATE stores the new image in an un-programmed flash, it is not active until a power cycle
forces the new image to be loaded into shadow RAM in the controller. Until a power cycle occurs,
EEUPDATE functions like /verify, and /mac_dump will not work correctly. Once an I210 is programmed
and running with a valid image, updates can be performed with only a system reboot with some
exceptions
You will need a Premier account in order to get access to these documents.
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
@Diego_INTEL
Diego_INTEL
exceptions
@Diego_INTEL
rhoffmann477
 Hello Diego,
Thank you for kind and detailed explanations. I now have functional i210-IS devices! A few important notes, IMHO, I would like to share:
1) In my design, the i210 devices were connected to 4Mbit SPI flash devices. This is obviously not large enough to upload a 8Mbit binary image. But an external flash device is actually not required, so I removed them.
2) To be able to write into the iNVM internal memory of the i210-IS, the pin NVM_SI shall be pulled low.
3) The configuration file I used is I210_Invm_SerDesKX_NoAPM_v0.6.txt available in #513655. I used the eeupdate64e utility from document #348742 to first list the devices which are present
NIC Bus Dev Fun Vendor-Device Branding string
1 45 00 00 8086-125D Intel(R) Ethernet Controller I226-IT
2 46 00 00 8086-125D Intel(R) Ethernet Controller I226-IT
3 48 00 00 8086-1531 Intel(R) I210 Blank NVM Device
4 49 00 00 8086-1571 Intel(R) I210 Blank NVM Device
Then upload the configuration file and configure the MAC address
> ./eeupdate64e /NIC=3 /FILE=./I210_Invm_SerDesKX_NoAPM_v0.6.txt /MAC=7cd120003001 /INVMUPDATE
4) The devices are now listed by lspci as a "backplane connection" controllers
30:00.0 Ethernet controller: Intel Corporation I210 Gigabit Backplane Connection (rev 03)
31:00.0 Ethernet controller: Intel Corporation I210 Gigabit Backplane Connection (rev 03)
Kind regards,
Ralph
Diego_INTEL
Hello Ralph,
You are very welcome, also, thank you very much for your notes, this may be very useful to have in the community.
@Diego_INTEL
