Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
923 Discussions
Update MAC Address on Ethernet Controller of Custom Board
Aman10
Hello
As we have Custom PCB Board and Using SOM Module of Intel ATOM as HOST.
As Earlier we are Checking Ethernet Controller NVM is Blank so After Raised Query and Continuous Communication with Intel Support team we got EEUPDATE Tool for Programming of Ethernet Controller NVM, We Programmed the NVM and tried to Update MAC Address but not Available to Update.
we are Updating MAC Address As following 00E04B776072
so it's Correct Value for Updating MAC Address or Something Else we have to Write?
and What else we can do for Updating the MAC Address.
Thank You
Diego_INTEL
Hello @Aman10,
You can check document #630505 - Intel® Ethernet Controller Debug Handbook
2.5.17 How to Write a MAC Address using the Intel LAN Tool
@Diego_INTEL
Aman10
I tried the method Based on Document but Still am not Available to Update MAC Address.
i Will attach Following Photo of Command and What MAC Address i Dumped Along with Error.
Please Check and if anything you know regarding this please let me know.
Diego_INTEL
Hello @Aman10,
Can you check what does appear when you run the command:
eeupdate /nic=1 /adapterinfo
After the MAC update have you did AC Power Off and On?
@Diego_INTEL
Aman10
Hello
Yeah I tried with Power off one After Updating MAC Address but it Still Showing the Same Error.
Thank You
Aman
Aman10
Thank you for the Response, i  will Check that Document.
Also are you Know how to Update MAC Address from EEUpdate tool?
