Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
916 Discussions
Wake on LAN not working on i210 ethernet controller.
NK89
Hi Team,
We designed custom board using NXP iMX8MQ processor. We used Intel i210 ethernet controller in our design and able to bring up that interface.
But, we facing issue on Wake on LAN functionality of i210 controller.
Logs are attached as below.
root@imx8mqpicoitx:~#
root@imx8mqpicoitx:~# ifconfig eth1
eth1     Link encap:Ethernet HWaddr 00:a0:c9:00:00:00
         inet addr:192.168.2.169 Bcast:192.168.3.255 Mask:255.255.252.0
         inet6 addr: fe80::2a0:c9ff:fe00:0/64 Scope:Link
         UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
         RX packets:955339 errors:0 dropped:0 overruns:77 frame:0
         TX packets:69013 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:1000
         RX bytes:1139908902 (1.0 GiB) TX bytes:4052993 (3.8 MiB)
         Memory:18100000-1817ffff
root@imx8mqpicoitx:~# ethtool eth1
Settings for eth1:
       Supported ports: [ TP ]
       Supported link modes:  10baseT/Half 10baseT/Full
                               100baseT/Half 100baseT/Full
                               1000baseT/Full
       Supported pause frame use: Symmetric
       Supports auto-negotiation: Yes
       Advertised link modes: 10baseT/Half 10baseT/Full
                               1000baseT/Full
       Advertised pause frame use: Symmetric
       Advertised auto-negotiation: Yes
       Speed: 1000Mb/s
       Duplex: Full
       Port: Twisted Pair
       PHYAD: 1
       Transceiver: internal
       Auto-negotiation: on
       MDI-X: off (auto)
       Supports Wake-on: pumbg
       Wake-on: g
       Current message level: 0x00000007 (7)
                              drv probe link
       Link detected: yes
There is wake-on functionality is ON as per above logs. When I freeze the processor and send magic packet from another system our processor does not coming out from freeze mode.
Is there any configuration missing from my side? Or, the WOL functionality is not worked in i210 Linux driver?
Let me know if you require more information from my side.
Thanks & regards,
Nirmal
CarlosAM_INTEL
Hello, @NK89​:
Could you please let us know how many units of the project related to this circumstance have been manufactured? How many are affected? Could you please give the failure rate? Also, could you please list the sources that you have used to design it and if it has been verified by Intel?
Could you please explain the procedure followed to obtain the cited driver?
We are waiting for your answer.
@Mæcenas_INTEL​.
