Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
930 Discussions
We would like to test I350 (L2A3341A1C-BH-DB) MDI interface without CPU. Is there any related command information that you could provide to us? Thanks.
chen1
CarlosAM_INTEL
Hello, @1000038531941.4576506006539324E12​:
Could you please let us know if this thread is related to the following forum?
https://forums.intel.com/s/question/0D50P00004XNSGb/we-have-an-arm-server-design-that-uses-i350-l2a3341a1cbhdb-ethernet-controller-please-provide-us-f-w-thank-you
Could you please clarify if your consultation is related to a third_party or your own design? Please give all the details (part number, model, name of the manufacturer, where is the documentation) of the project related to this situation if it is a third-party device.
In case that its your design, could you please let us know how many units of the project related to this circumstance have been manufactured? How many are affected? Could you please give the failure rate? Also, could you please list the sources that you have used to design it and if it has been verified by Intel?
We are waiting for your answer to these questions.
@Mæcenas_INTEL​.
