Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
914 Discussions
X710-DA2 Update not working - Unsupported OROM Combo Image
mitzsch
Updating an Intel X710-DA2 to the latest version (9.30) does not work and fails with the following output:
I also tried it with Windows but that also failed with the same error. Rerunning an older fw package (e.g. v9.10 - note v9.20 also fails) works.
We already discussed it here => X710-DA2 Update not working - Unsupported OROM Combo Image - Intel Community
A user (with the same problem) over there found a "workaround" for updating the firmware but with the downside of losing some functions.
Also as written there. Something seems wrong with the BootIMG.FLB / OROM Image. On the same system, I can rerun the v9.10 update package without a problem, so it somehow must be a problem with the newer firmware package.
The BootIMG.FLB file in the old update package v9.10 is also substantially larger 1 683 014 bytes vs 1 379 463 bytes. I guess something is missing there. Quickly analyzing those files in a text editor also shows something is clearly missing in the new version.
Also for comparison:
v9.01 BootIMG.FLB = 1 683 014 bytes - update works
v9.10 BootIMG.FLB = 1 683 014 bytes - update works
v9.20 BootIMG.FLB = 1 310 096 bytes - update does not work
v9.30 BootIMG.FLB = 1 379 463 bytes - update does not work
I hope this time it's the right subforum. lol Thanks!
Alex
Diego_INTEL
Hello @mitzsch,
Can you check if you still have the issue when using the latest driver?
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
Internally, I'm not seeing any issues related reported to the version 9.3, as the losing functions may be because the actual driver is not compatible and must be updated.
@Diego_INTEL
mostwanted002
Hey @Diego_INTEL
The losing functionality was the aftermath of getting the card to flash the NVM using PREBOOT utility. The whole method and results are posted here : https://community.intel.com/t5/Ethernet-Products/X710-DA2-Update-not-working-Unsupported-OROM-Combo-Image/m-p/1523567#M34502
The whole issue is that NVM updates ahead of 9.10 (i.e. 9.20 and 9.30) do not have the Combo ROM option for iSCSI+PXE+UEFI
mostwanted002
Diego_INTEL
Hello @mostwanted002@mitzsch,
Thank you for the details, I understand better the situation, I thought that the issue was in an error in updating to the newer firmware.
Yes, the iSCSI Boot has being removed, mentioned in the bootutil.txt.
"NOTES:
- Legacy iSCSI Boot and CLP images are not supported and cannot be loaded or configured."
https://www.intel.com/content/www/us/en/download/15755/intel-ethernet-connections-boot-utility-preboot-images-and-efi-drivers.html?
In @mitzsch's case, it may be best to stay in 9.1 and don't update as legacy iSCSI needed to be removed, there is not much we can do about. My apologies for the inconvenience.
@Diego_INTEL
