Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
944 Discussions
i210: How programmatically use the SDP signals to correct the offsets for 4 i210 devices at boot time?
BAlsa
I have 4 i210 device on one board. I want to make sure that the four of them has the exact timer offset (will be used in 1588 setup).
Because they may have different initialization time they may end up with different time offset. I want to use the SDP at boot time to set the four of then on the same time offset.
Thank you
Bassam,
CarlosAM_INTEL
Hello Alsanie,
Thank you for contacting the Intel Embedded Community.
The information that may help is stated in section 7.8.3.3, on pages from 343, 344, and 345 of the http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i210-ethernet-controller-datasheet.pdf Intel(R) Ethernet Controller I210 Datasheet document # 333016.
Please let us know if this information is useful to you.
Carlos_A.
BAlsa
Thank you Carols for the fast response. I think I need to know exactly what I need to do in order to to get the four of the i210 to have the exact same time. Is it something I need to make on the kernel driver code or I can use the driver interface to accomplish it? The documentation you pointed me to have good info, but I am still not clear how I can get the four of the i210 to have the same exact time after initialization.
Basically a way to correct for offset at initialization timer.
Thank you
CarlosAM_INTEL
Hello Alsanie,
Thanks for your update.
We suggest you verify that your design through the Schematic Review Service following the procedure stated at:
https://edc.intel.com/schematic-review/?language=en https://edc.intel.com/schematic-review/?language=en
This service requires that your Embedded Design Center (EDC) account should be updated to Privileged type. To request an upgrade from your Basic EDC account to a Privileged account, go to http://www.intel.com/content/www/us/en/embedded/embedded-design-center-support.html http://www.intel.com/content/www/us/en/embedded/embedded-design-center-support.html and click on "Manage Your Intel Profile" found in the "Manage Your Account" section of the page. From there you can request an upgrade. After you submit the application, please let us know and we will expedite the review of your application. The application can be found at:
https://www-ssl.intel.com/content/www/us/en/forms/intelligent-systems/registration-po.html https://www-ssl.intel.com/content/www/us/en/forms/intelligent-systems/registration-po.html
We suggest you use a business email address to evade any inconvenience. Please avoid the free email provider's address (such the provided by Hotmail, Gmail, yahoo, or others).
Carlos_A.
BAlsa
every time I try to go the upgrade page (you mentioned above) I get redirected to this page:
http://www.intel.com/content/www/us/en/embedded/embedded-design-center.html Intel® Embedded Design Center
Thank you
Bassam
