Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
915 Discussions
intel i215is do not work with SGMII SFP
Dmitriy1
Good day everyone
Now i try to test SGMII SFP module with i210is chip
1.Use flash w25q64jv, flash by file Dev_Start_I210_Sgmii_NOMNG_16Mb_A2_3.25_0.03.bin. do not work
2.Try to change registers in invm file 0x0d  0x1538 and 0x24 0x06A0.do not work
I see status scope link but the ping is unsuccessful
need help !!!!
Achilles_Intel
Hello Dmitriy1,
Just to clarify, are you designing/customizing your Intel® Ethernet Controller I210-IS when you encountered this issue?
Let us know if you need clarifications. If we do not receive a response, we will make sure to follow-up after 3 business days.
Thank you and have a nice day.
Achilles M.
Intel Customer Support
Dmitriy1
Good day
we are developers and produce network cards with 4x and 8x ports, at the moment there is an order for modules with i210is and external SFP phy such as SFP-FX-MM-SGMII. I can't get it started.
The link appears but the packets do not pass
p.s. the usual 1gb or sfp works normaly, the problem only with sfp SGMII
Achilles_Intel
Hello Dmitriy1,
Thank you for you quick response.
We have a specific forum for design/customization inquiries of Intel® Ethernet Controller I210-IS. For faster responses and better assistance, we will move the thread to the designated team. Please wait for their reply within 1-2 business days.
Achilles M.
CarlosAM_INTEL
Hello, @Dmitriy1:
You should confirm that the affected implementation fulfills the guidelines stated in the answer to questions 2.11, 2.13, 2.16, 2.22, 2.29, and 2.30, on pages 7, 8, 9, 10, and 11 of the Intel® Ethernet Controller I210/I211 Frequently Asked Questions (FAQs) that can be found in the following website:
 https://cdrdv2.intel.com/v1/dl/getContent/334026
@CarlosAM_INTEL.
