Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
957 Discussions
unable to initialize adapter 1code c86a200d
QST
After i tried to change the device ID with the eeupdate64e tool,The ‘/mac’ command is currently not functioning correctly.how should i solve this problem and how to avoid this problem again?
Diego_INTEL
Hello @QST,
What ethernet controller are you using? Is it a blank device?
@Diego_INTEL
QST
Hello @Diego_INTEL ,
Thank you for your reply. My idea was to modify the i219-lm (8086-157b) to i217-lm (8086-153a). I used eeupdate to change the 0d bit in its EEPROM. After the modification, error code c86a200d occurred, and now I have restored it to its original state.Could you please advise on how I should proceed to realize the idea of modifying the i219-lm (8086-157b) to i217-lm (8086-153a)?
@QST
Diego_INTEL
Hello @QST,
No, my apologies, you can only use the images for the i219 available, as I know, there are some images that are compatible for different SKUs for the same controller but I have not seen anything like to change the image to show a different controller name.
@Diego_INTEL
QST
Thank you for the clarification and for your detailed explanation.
@QST
