1258 Discussions
Baytrail E3800 Hardware Straps: Security Flash Descriptors
NGhor
Hi all,
On the Baytrail E3800 what is the hardware Strap "Security Flash Descriptors " actually used for.
Normally I am assuming it is left default is high (normal) instead of the other option (0=override).
Thanks in Advance.
Naveed
CarlosAM_INTEL
Hello, @NGhor:
The information that may help you is stated in Table 32, on page 68 of the Intel Atom(R) Processor E3800 Product Family Datasheet document # 538136. It can be found when you are logged into your Resource & Design Center (RDC) privileged account on the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/538136.htm
The RDC Account Support form is the channel to process your account update request or report any inconveniences with the provided site. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
By the way, could you please clarify if this thread is related to a technical issue? In case your answer is affirmative give a detailed description of the problem.
@CarlosAM_INTEL.
CarlosAM_INTEL
Hello, @NGhor:
@CarlosAM_INTEL.
NGhor
Thanks. I found what I needed in section 31.2.3.3 Descriptor Security Override Strap.
This is review of an old design as we were planning on using the previous design as the base for a new product.
