Hi Team, I would like to know that if I purchase a C3508 processor, which are the boot-process related firmwares/softwares would I get along with it (like BIOS, firmware, bootloader, etc.), and which ones among those would be customizable. References to any existing documentation would help me further to understand.
Hello @KnowDenv25 ,
Sure, every piece of firmware is customizable for the C3508 processor; either that you work with a BIOS Engineer or an authorized BIOS vendor (AMI, Phoenix, Inside) you can customize the FW according to your needs; however its strongly recommended that you work with any of the mentioned BIOS developers. If you decide working with your BIOS engineer on your own, then the Intel Coreboot + FSP is a good option and is available at github:
https://github.com/coreboot/fsp/tree/master/DenvertonNSFspBinPkg
Jaime L.
