C3708 i2c address
Jing1127
Hello
We use C3708 for our CPU ,after we detect i2c in Linux shell.We found that there is an address we don't define, but always show in our i2c result.That address is 0x08. I want to ask what is that address? Is this address that originally existed in the C3708?
Thanks~~
Adolfo_S_Intel
Hello, @Jing1127
Coudl you please indicate the exact linux command you used, and share the output?
BR,
@Adolfo_S_Intel
Jing1127
Hello @Adolfo_S_Intel
I use  the command is i2cdetect -y 0 and my result is as show below.
Thanks~~
Adolfo_S_Intel
Hello, @Jing1127 ,
The board you are using is a Third Party board or it is manufactured by your own company?
BR,
@Adolfo_S_Intel
Jing1127
The board is made by ourselves .We confirm that we don't define this address.
So we want to know if this address may exist in C3708?
Thanks~~
Adolfo_S_Intel
Hello, @Jing1127 ,
Do you see the device in the  /sys/bus/i2c/devices/  if so, as suggested by this article: https://www.kernel.org/doc/html/latest/i2c/i2c-sysfs.html it might be possible that the device folder has a name file or information about the type of device.
Also can you confirm what do you see with the commands:
  i2cget -y -f 0 or  i2cget -y -f 1
@Adolfo_S_Intel
Jing1127
Sorry for replying so late.
I use the command # ls /sys/bus/i2c/devices/,and it show as below.
I try some command and found as below.
Is that 0x08 is address of LNXCPU or device in C3708?
Also I try the command i2cget -y -f 0 as below.
But it seems like 0x08 is not exists.
Thanks~~
Adolfo_S_Intel
Hello, @Jing1127 ,
Can you show me the contents of /sys/bus/i2cdevices/i2c-0/?
What do you see on the LNXCPU:08 folder and what do you see on the device:08 folder?
I would suggest you also consult within the Linux community.
BR,
@Adolfo_S_Intel
Jing1127
The result of the contents of /sys/bus/i2cdevices/i2c-0/ show as below.
The result on the LNXCPU:08 folder and  the device:08 folder as below
Thanks~~
