1237 Discussions
CPU C3558 10G FCS ERROR :C3558 10G 端口FCS报错
FYhao123
Hello! I am using a CPU: C3558 with 10G LAN0: port0 (FCS error), port1 (NO FCS error). I need the Sl tune tool: 10G PHY tool (as well as the method to install the phy tool on Ubuntu Server 22.04), the register and parameter documentation for the 10G LAN0 of C3558, and commands such as receive equalization (RxEQ), transmit pre-emphasis (TxPre), transmit de-emphasis (Tx De-emphasis), and TxAmplit for signal debugging parameters. For example, the SI parameter format is: <main><pre><post><tx-boost>, thank you。        PS:   After testing, LAN0: port0--eth0 is normal, while port1---eth1 has packet errors as shown in the attachment, with the same FCS issue. Other Hygon modules also have the same problem, which can be resolved by debugging SI tune. The operating system is Ubuntu Server 22.04. Please provide the 10G PHY tool (as well as the PHY tool and installation method for Ubuntu Server 22.04), the register and parameter documentation for the 10G LAN0 of C3558, and the commands used for debugging.
您好!我使用CPU :C3558 的10G LAN0:port0(FCS error),port 1:(NO FCS error)需要Sl tune tool:10G PHY tool(以及ubuntu server 22.04安装phy tool方法)和C3558的10G LAN0 寄存器和参数文档和使命令,如接收均衡RxEQ,发送预加重(TxPre),发送去加(Tx De-emphasis),TxAmplit进行信号调试参数,如SI参格式为:<main><pre><post><tx-boost>,谢谢
PS:经过测试,LAN0: port0--eth0正常, port1---eth1有错包的情况,如附件所示,同样FCS问题,其他海光模块同样问题有调试SI tune解决 操作系统为ubuntu server 22.04 ,还请您提供10G PHY tool(以及ubuntu server 22.04 的PHY工具和安装方法)和C3558的10G LAN0 寄存器和参数文档和调试使用命令
Jaime_Lizarme
Hello @FYhao123 ,
Unfortunately, the C3558 CPU product has reached End Of Servicing; therefore, its support is and tools are no longer available.
Jaime L.
FYhao123
Dear Jaime_Lizarme :
         The 10G eth3 of C3708 4X10G also has this FCS issue. Can serdes debugging SI tools be provided for C3708? What date is the service end period?
       Thank you.
FYhao123
The 10G eth3 of C3708 4X10G also has this FCS issue. Can serdes debugging SI tools be provided for C3708? What is the service period? Thank you.        C3708的10G: 4X10G的eth3也有此FCS问题,C3708可以提供serdes 调试SI工具吗?服务期限是什么时候? 谢谢
