Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
1258 Discussions
Cannon Lake PCH H Corner NCTF Test
WOtt
Referring to the Intel document 566757, page 64, a PCB routing example is shown where the pins A2 and B1 are intended to route to test points for NCTF test functionality.
The document does not clearly state if A2 and B1 are shorted or connected on the die package to VSS(A2) or VCC(B1) respectively .
On CRB, 571483, they are obviously connected to VSS(A2) and VCC(B1) externally (what would be tricky if they were shorted on die package).
How is the electrical relationship between A2/B1, A48/B48, BG48/BF49, BG2/BF1, VCC and VSS for Cannon Lake PCH-H?
Could you also confirm that the Coffe Lake H CPUs Corner pins C1/B1, C38/B38, BR38/BT36 and BR2/BP1 are shorted together on die package and do not have any electrical potential?
Thank you for your help.
Best regards, Walt
CarlosAM_INTEL
Hello, WOTT :
In order to help you, we will contact you via email.
Carlos_A.
RGumu
Hi Carlos,
Could you also help me about the usage of the Coffee Lake H CPU and Cannon Lake PCH-H NCTF corner pad? I could not understand what should we do on the schematic?
Best Regards
CarlosAM_INTEL
Hello, Raşit:
Carlos_A.
RGumu
Hi Carlos,
Have you ever had a chance to look at this issue?
Best Regards
Raşit
CarlosAM_INTEL
​Hello, @RGumu​ :
Thanks for your reply.
Could you please let us know if you have received our email of the past November 20th, 2018? In case that your answer is affirmative, could you please confirm that you have followed our suggestion?
We really appreciate your cooperation.
@CAgui2​.
RGumu
Hi Carlos,
I received a mail on 20th Nov, saying that "In order to help you, we will contact you via email." After that I have not received any suggestion email.
Best Regards
CarlosAM_INTEL
​Hello, @RGumu​ :
In order to be on the same page, could you please review on your spam inbox if there is a notification from our side? In case that your answer is negative, could you please give us your email address?
Waiting for the information that may answer these questions.
@CAgui2​
RGumu
Hi Carlos
Unfortunately there is no email on my mails junk box.
My email address rgumus@aselsan.com.tr
Best Regards
Rasit
CarlosAM_INTEL
​Hello, @RGumu​:
Thanks for your soon answer.
Please let us know if you receive our notification to the provided email.
@CAgui2​ .
