DF80641010507065SR0DB
BXion2
Anyone here have a better datasheet's dimension info? The datasheet i have is too small and "Blurry" not readable.
Diego_INTEL
Hello @BXion2,
I think what you need is the document called Thermal and Mechanical Design Guide but for the D2000 and N2000 series, that is old and being not supported may be hard to find.
I found that here are some documents regarding old families, but the TMDG is not available for the D2000 and N2000, it is available for other families, you can check if they may be of help.
https://www.intel.com/content/www/us/en/products/docs/processors/atom/technical-resources.html
@Diego_INTEL
