1230 Discussions
Deleted flash of management controller of Development Board 1-D510 !!!
SZann
i have accidentally started the firmware update of the H8S/2472 management controller on the 1-D510 development board, and it deleted the contents of the flash memory ...
Now when you connect the power supply it shows the message "WARNING: NO IMAGE FOUND. PLEASE DOWNLOAD AN APPROPRIATE CPUDIMM IMAGE" however the "Program Flash via XModem Download" menu option still works.
So, is it possible to download a firmware image from somewhere ? Then i will be able to repair te damage done.
JOHAN_V_Intel
Hi
The procedure is documented here on how to update your firmware on the H8 controller
... http://www.intel.com/content/www/us/en/intelligent-systems/luna-pier/edb-1-n450-1-d510-user-guide.html http://www.intel.com/content/www/us/en/intelligent-systems/luna-pier/edb-1-n450-1-d510-user-guide.html.
I will provide you an image by email shortly.
Johan
