1255 Discussions
Driver needed Intel Elkhart Lake Atom x6211E
JBGBO
We need a graphic driver for the Windows IoT 2016 version 1607
CarlosAM_INTEL
Hello, @JBGBO:
We want to address the following question:
Could you please clarify if the requested driver is for a design implemented by you or for a third-party device? In case it is a third-party unit, please let us know the name of the manufacturer, the part number, and where we can find the information related to it.
We are waiting for your answer.
@CarlosAM_INTEL
JBGBO
Good day Carlos,
The POC40 was purchased through a supplier of fanless computing. We did not modify any of the hardware. It came preloaded with Windows 10 Version 1607 or Windows 10 Enterprise 2016 LTSB. The fanless system specifications, I will upload for your viewing, also the OS version. The maximum viewing is 1024 x 768. Which the specifications as advertised is 1x DisplayPort connector,
supporting 4096 x 2160 resolution @ 60Hz.
JBGBO
WE really would like to get this resolved for our IoT rollout for the manufacturing environment.
CarlosAM_INTEL
Hello, @JBGBO:
Thanks for your replies.
You should consider that the devices developed by the manufacturer of the third-party unit related to your request should be supported, as a reference, by filling out the form stated on the following website:
https://coastipc.com/technical-support
@CarlosAM_INTEL
