1267 Discussions
EG20T - I2C CreateFile return a error with Windows XP
AHube2
if I want to use the following call it returns always an error. I think the name "I2CDev" is wrong.
hI2CDevice = CreateFile(\\\\.\\I2CDev, ...
Can anybody help?
FMcNu1
Valued Contributor I
Hello Andreas,
I think you may be a Privileged member of the Intel® Embedded Community. If that is true, you may also want to post your question to the Intel® e-Help desk, which is staffed by Intel representatives who support select Intel embedded platforms including Intel Atom™ (The EG20T is the companion I/O hub for Atom™ E6xx)
Try to access e-Help here:
/community/en/intel_e-help_desk/low_power_platforms http://embedded.communities.intel.com/community/en/intel_e-help_desk/low_power_platforms
If you are not already a Privileged member, you can request an upgrade to your community account here:
https://edc.intel.com/My-Account.aspx https://edc.intel.com/My-Account.aspx
I hope this helps.
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
