1267 Discussions
Embedded graphic driver development assistance for Intel Pineview
SZhur
Hello.
Me was tasked to write graphic driver for embedded os kernel "On Time RTOS-32".
Where I can find Programmer's Reference Manual (PRM) and some other datasheets for Intel Pineview graphic adapter (VendorId:DeviceId: 8086:A011)?
Kirk_B_Intel
I just did a search and the 2010 PRM has the details for Pinview in it as I found a reference to Pineview in the Volume 3 part 2 CPU PRM in there. THAT 2010 set is the "PRM" that we have available for Pineview. Google found it for me, I believe it would find it for you as well. http://lmgtfy.com/?q=Intel+Pineview+PRM http://lmgtfy.com/?q=Intel+Pineview+PRM
Kirk_B_Intel
Pineview (N400/500 and D400/500 Series) is a relatively out of date platform. You might want to consider using something a bit more modern that has better information availability.
If a PRM exists for that series chipsets, it will be out on the Intel OpenSource Technology Center website. Here: https://01.org/linuxgraphics/documentation https://01.org/linuxgraphics/documentation
I would suggest looking at the 2010 set or the G45 PRM as those are the closest that exist for that chipset.
Something to keep in mind is that basically, that series chipset utilized a Graphics engine and Display controller that is basically the 945G/GM which is basically the same as in the G45 and the 2010 products.
Hope that helps.
Natalie_Z_Intel
Hi, Sergey! Kirk addressed your graphics driver question. For added information, if you need to research any technical content on Intel® Atom™ Processors 400 and 500 Series with Intel® 82801HM I/O Controller Hub (Formerly http://www.intel.com/content/www/us/en/intelligent-systems/luna-pier/embedded-intel-atom-400-and-500-series-features-n450-d410-d510.html Luna Pier (Pineview + Intel® ICH8M)), the hardware section of thehttp://www.intel.com/content/www/us/en/intelligent-systems/embedded-design-center.html EDC will have it. As Kirk suggests, there are http://www.intel.com/content/www/us/en/intelligent-systems/intel-atom-embedded-maximum-performance-watt-intel-processors.html newer platforms based on Atom. For drivers, firmware, tools, and ecosystem products for software developers, check out the http://www.intel.com/content/www/us/en/intelligent-systems/embedded-software-tools-for-developers-to-debug-and-optimize.html EDC Software page. Hope this helps!
SZhur
How happened the lost documentation on Intel Pineview graphic adapter? Can I find documentation at archives? https://www-ssl.intel.com/content/www/us/en/forms/corporate-archives-contact-us.html https://www-ssl.intel.com/content/www/us/en/forms/corporate-archives-contact-us.html
Could Privileged User account on EDC help me to find Intel Pineview documentation?
Thanks: Kirk, LynnZ.
Kirk_B_Intel
