Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
1265 Discussions
Enabling ROM Bypass via using FIT
tKim01
I have some questions regarding enabling/using the ROM Bypass for an Apollo Lake-I (E3950) processor.
How can the ROM bypass be enabled in the FIT tool? The setting is greyed out, and when the image is compiled the ROM bypass region is defined as unused.
Does the ROM bypass enable hardware strap (GPIO_39) have any effect when the region is not correctly included into the SPI flash image?
I'm using FIT version 3.1.60.2280, as released with the TXE FW release package 3.1.70.2334.
Thanks in advance,
CarlosAM_INTEL
Hello, @tKim01​:
We suggest you follow the procedure stated in Appendix A, on pages 28, 29, and 30 of the Apollo Lake Platform - Intel(R)Trusted Execution Engine [Intel(R)TXE]  Firmware Bring-Up User Guide {Revision 1.1, August 2016} that can be found as a reference at:
https://usermanual.wiki/Document/APLIntelRTXEFWBringupGuideV11.128793216/view
@Mæcenas_INTEL​.
