FSP with debug info
ZVere
I got the following output after compiling coreboot with a debug FSP for baytrail:
============= PEIM FSP v1.0 (VLYVIEW0 v0.0.3.5) =============
Register PPI Notify: DCD0BE23-9586-40F4-B643-06522CED4EDE
Install PPI: 8C8CE578-8A3D-4F1C-9935-896185C32DD3
Install PPI: 5473C07A-3DCB-4DCA-BD6F-1E9689E7349A
The 0th FV start address is 0x000FFFE0400, size is 0x00017C00, handle is 0x0
Register PPI Notify: 49EDB1C1-BF21-4761-BB12-EB0031AABB39
Register PPI Notify: EA7CA24B-DED5-4DAD-A389-BF827E8F9B38
Install PPI: B9E0ABFE-5979-4914-977F-6DEE78C278A6
Install PPI: DBE23AA9-A345-4B97-85B6-B226F1617389
Install PPI: 06E81C58-4AD7-44BC-8390-F10265F72480
Install PPI: 01F34D25-4DE2-23AD-3FF3-36353FF323F1
Install PPI: 49EDB1C1-BF21-4761-BB12-EB0031AABB39
Notify: PPI Guid: 49EDB1C1-BF21-4761-BB12-EB0031AABB39, Peim notify entry point: FFFE0FE4
The 1th FV start address is 0x000FFFB0000, size is 0x0002F400, handle is 0xFFFB0000
Install PPI: A55D6970-1306-440C-8C72-8F51FAFB2926
PcdMrcInitTsegSize = 8
PcdMrcInitMmioSize = 800
PcdMrcInitSPDAddr1 = A0
PcdMrcInitSPDAddr2 = A2
Setting BootMode to 0
Install PPI: 1F4C6F90-B06B-48D8-A201-BAE5F1CD7D56
Register PPI Notify: F894643D-C449-42D1-8EA8-85BDD8C65BDE
About to call MrcInit();
BayleyBay Platform Type
AutoSelfRefreshEnable = 0x2
RID = 0x11.
Reg_EFF_DualCH_EN = 0x100301C0.
CurrentMrcData.BootMode = 4
C0.D0: SPD not present.
C1.D0: SPD not present.
What should I do with this information ?
Should I use it in Intel's BCT to modify some default FSP values ?
or should I use it to modify the current devicetree.cb ?
Is there a detailed documentation explains what is the meaning of each line in the messages I got ?
Thank you,
Zvika
CarlosAM_INTEL
Hello, @ZVere​:
We suggest you refer to the suggestions and information stated in the Intel(R) Firmware Support Package [FSP] for Intel(R) Atom(TM) Processor E3800 Product Family: Integration Guide document # 331165 that may answer your questions.
This document can be found at the following website:
https://www.intel.com/content/dam/www/public/us/en/documents/guides/atom-e3800-fsp-integration-guide.pdf
We hope that this information is useful to you.
@Mæcenas_INTEL​.
