1267 Discussions
GMA 3150 Graphics Driver Installation Errors
CHarr
I am trying to install the GMA 3150 graphics driver (version 15.12.75.50.7.2230) in Windows PE (both version 3.0 and 4.0).
I am able to use DISM to successfully add the driver to the offline WinPE image.
But the graphics driver is not installed at WinPE boot time. I cannot find any clues why - PE does not appear to log any errors for PNP driver installation, other than network driver installation during wpeinit.
So, after booting to PE, I am using devcon to manually install the driver, and here's the strange thing: it fails to install the first time, but DOES install successfully the second time.
I'd like to try to resolve the errors reported during the first install, to see if this leads to a solution for a working graphics driver at WinPE boot time.
Here is the beginning of setupai.dev.log for the first install attempt, in WinPE 4:
>>> [Device Install (UpdateDriverForPlugAndPlayDevices) - pci\ven_8086&dev_a011]
>>> Section start 2012/12/25 20:00:28.338
cmd: devcon install d:\ppc_intel\graphics\igdlh.inf "pci\ven_8086&dev_a011"
dvi: {Build Driver List} 20:00:28.338
dvi: Searching for hardware ID(s):
dvi: pci\ven_8086&dev_a011
cpy: Policy is set to make all digital signatures equal.
dvi: Created Driver Node:
dvi: HardwareID - PCI\VEN_8086&DEV_A011
dvi: InfName - d:\ppc_intel\graphics\igdlh.inf
dvi: DevDesc - Intel(R) Graphics Media Accelerator 3150
dvi: Section - iPNVM0
dvi: Rank - 0x00f40000
dvi: Signer Score - WHQL Unclassified
dvi: DrvDate - 10/24/2010
dvi: Version - 8.14.10.2230
dvi: {Build Driver List - exit(0x00000000)} 20:00:28.369
dvi: {DIF_SELECTBESTCOMPATDRV} 20:00:28.369
dvi: Using exported function 'DisplayClassInstaller' in module 'X:\windows\system32\DispCI.dll'.
dvi: Class installer == DispCI.dll,DisplayClassInstaller
dvi: No CoInstallers found
dvi: Class installer: Enter 20:00:28.369
dvi: Class installer: Exit
dvi: Default installer: Enter 20:00:28.385
dvi: {Select Best Driver}
dvi: Class GUID of device remains: {4d36e968-e325-11ce-bfc1-08002be10318}.
dvi: Selected:
dvi: Description - [Intel(R) Graphics Media Accelerator 3150]
dvi: InfFile - [d:\ppc_intel\graphics\igdlh.inf]
dvi: Section - [iPNVM0]
dvi: {Select Best Driver - exit(0x00000000)}
dvi: Default installer: Exit
dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 20:00:28.385
sto: {Import Driver Package: d:\ppc_intel\graphics\igdlh.inf} 20:00:28.385
sto: Driver Store = X:\windows\System32\DriverStore [Online] (6.2.9200)
sto: Driver Package = d:\ppc_intel\graphics\igdlh.inf
sto: Architecture = x86
sto: Flags = 0x00001001
inf: Provider = Intel Corporation
inf: Class GUID = {4d36e968-e325-11ce-bfc1-08002be10318}
inf: Driver Version = 10/24/2010,8.14.10.2230
inf: Catalog File = igdlh.cat
inf: Version Flags = 0x00000001
sto: Driver package already imported as 'oem0.inf'.
sto: Driver Store Filename = X:\windows\System32\DriverStore\FileRepository\igdlh.inf_x86_7e023b84287ce181\igdlh.inf
sto: {Import Driver Package: exit(0x00000000)} 20:00:28.416
dvi: {Plug and Play Service: Device Install for ROOT\DISPLAY\0000}
ndv: Infpath=X:\windows\INF\oem0.inf
ndv: DriverNodeName=igdlh.inf:5f63e534909ad42f:iPNVM0:8.14.10.2230:pci\ven_8086&dev_a011
ndv: DriverStorepath=X:\windows\System32\DriverStore\FileRepository\igdlh.inf_x86_7e023b84287ce181\igdlh.inf
dvi: Class GUID of device changed to: {4d36e968-e325-11ce-bfc1-08002be10318}.
ndv: {Core Device Install} 20:00:28.578
dvi: {DIF_ALLOW_INSTALL} 20:00:28.671
dvi: Class installer: Enter 20:00:28.703
dvi: Default installer: Enter 20:00:28.734
dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 20:00:28.734
dvi: {DIF_INSTALLDEVICEFILES} 20:00:28.749
dvi: Class installer: Enter 20:00:28.749
dvi: {Build Driver List} 20:00:28.781
dvi: root\basicrender
dvi: HardwareID - ROOT\BASICRENDER
dvi: InfName - X:\windows\System32\DriverStore\FileRepository\basicrender.inf_x86_0a1186775c0cd2a8\basicrender.inf
dvi: DevDesc - Microsoft Basic Render Driver
dvi: Section - BasicRender
dvi: Rank - 0x00fb0000
dvi: Signer Score - INBOX
dvi: DrvDate - 06/21/2006
dvi: Version - 6.2.9200.16384
dvi: {Build Driver List - exit(0x00000000)} 20:00:29.061
dvi: {Build Driver List} 20:00:29.061
dvi: root\basicdisplay
cpy: Policy is set to make all digital signatures e...
