1229 Discussions
Hi Team, We are using the Apollo-lake SDK(E39XX), I trying to cross compiling the Redpine RS9113 proprietary driver getting linker errors. PFA error logs below. Can you please help us to resolve this error?
UMama
Build Configuration:
BB_VERSION      = "1.42.0"
BUILD_SYS      = "x86_64-linux"
NATIVELSBSTRING   = "universal"
TARGET_SYS      = "x86_64-poky-linux"
MACHINE       = "intel-corei7-64"
DISTRO        = "poky"
DISTRO_VERSION    = "2.7.1"
TUNE_FEATURES    = "m64 corei7"
TARGET_FPU      = ""
meta
meta-poky
meta-yocto-bsp
meta-intel
meta-intel-middleware
meta-filesystems
meta-networking
meta-oe
meta-python
meta-multimedia
meta-qt5
meta-intel-leafhill
meta-tpm2      = "master:09ba5a02f3572d3182f33aa4fa2a983b407493bc"
Error logs:
/home/mamathau/INTEL_E39XX/yocto_build/build/tmp/work/intel_corei7_64-poky-linux/kernel-devsrc/1.0-r0/recipe-sysroot-native/usr/bin/x86_64-poky-linux/../../libexec/x86_64-poky-linux/gcc/x86_64-poky-linux/8.3.0/ld: cannot find Scrt1.o: No such file or directory
/home/mamathau/INTEL_E39XX/yocto_build/build/tmp/work/intel_corei7_64-poky-linux/kernel-devsrc/1.0-r0/recipe-sysroot-native/usr/bin/x86_64-poky-linux/../../libexec/x86_64-poky-linux/gcc/x86_64-poky-linux/8.3.0/ld: cannot find crti.o: No such file or directory
/home/mamathau/INTEL_E39XX/yocto_build/build/tmp/work/intel_corei7_64-poky-linux/kernel-devsrc/1.0-r0/recipe-sysroot-native/usr/bin/x86_64-poky-linux/../../libexec/x86_64-poky-linux/gcc/x86_64-poky-linux/8.3.0/ld: cannot find crtbeginS.o: No such file or directory
collect2: error: ld returned 1 exit status
Makefile:1585: recipe for target 'wpa_supplicant' failed
make[1]: *** [wpa_supplicant] Error 1
make[1]: Leaving directory '/home/mamathau/RS9113.NBZ.NL.GENR.LNX.1.6.3/source/host/wlan/supplicant/linux/wpa_supplicant'
Makefile:403: recipe for target 'wpa_supplicant' failed
make: *** [wpa_supplicant] Error 2
CarlosAM_INTEL
Hello, @UMama​:
Reviewing the provide information, we found the following interesting information : MACHINE  = "intel-corei7-64" .
Based on this information, could you please let us know the procedure to obtain the driver associated to this condition? Could you please clarify if the affected implementation has been developed by you or it is a third-party one? Please give all the information (such manufacturer name, part number, model, and where its documentation can be found) if it is a third-party device. In case that it is your design, could you please clarify if it has been verify by Intel?
We are waiting for your clarification.
@Mæcenas_INTEL​.
UMama
Hi, @Mæcenas_INTEL
I am facing issue while cross compiling third party wpa_supplicant 2.6 in nl80211 with Apollo-lake build SDK.
link : http://www.linuxfromscratch.org/blfs/view/8.1/basicnet/wpa_supplicant.html
Before doing cross compilation Need to enable the nl80211 in wpa_supplicant/.config file
By default, the driver package comes with “BSD” support. we need Nl80211 support for Access point and Station modes.
Before doing cross compilation change the wpa_supplicant-2.6/wpa_supplicant/.config as mentioned below.
Need to comment below line in .config file
CONFIG_DRIVER_BSD=y
and enable below line
CONFIG_DRIVER_NL80211=y
add all LIBS and CFLAGS path in .config file.
CarlosAM_INTEL
Hello, @UMama​:
Thanks for your reply.
Your consultations of this driver or the ones posted in the provided website should be addressed as a reference to the channels listed in the following website:
http://www.linuxfromscratch.org/support.html
@Mæcenas_INTEL​.
UMama
Hi @Mæcenas_INTEL
Thanks for the replay
We build the Apollo-lake SDK as give below link
https://github.com/intel/iotg-yocto-bsp-public/tree/e3900/master
git checkout MR5-B-01
I just want know, is wpa_supplicant-2.6 compiled with this given SDK?
if yes, may I please get the steps to compile the wpa_supplicant-2.6.
CarlosAM_INTEL
Hello, @UMama​:
Your Intel(R) SDK consultations should be addressed to the following forum:
https://software.intel.com/en-us/forums/opencl
@Mæcenas_INTEL​.
