1231 Discussions
Intel Atom Baytrail Coreboot Stuck "CPU Index 0 - APIC 0 Unexpected Exception"
RSHAR3
We are using Intel Atom Baytrail E3826 in our Hardware. We observed some random Coreboot stuck issue during board bring up.
Its show error "CPU Index 0 - APIC 0 Unexpected Exception:6 @ 10:fffc002c - Halting" when this coreboot stuck problem comes.
When processor coreboot boots normally, the OS (VxWorks) gets loaded properly.
Could you please advise the possible root cause of the same from hardware side?
See the log print in working and non working scenarios.
DeividA_Intel
Hello RSHAR3,
I would like to inform you that we have a forum for these specific issues and products, so we are moving it to the "Embedded Intel Atom® Processors" forum so you can get better support for this matter.
Deivid A.
Diego_INTEL
Hello @RSHAR3,
The active support for BayTrail is no longer available.
Also, you may try contacting WindRiver for the support regarding VxWorks.
@Diego_INTEL
RSHAR3
This issue comes sometimes (like once or twice in 10 power cycle iterations).
Please find the below logs for the reference- (when Uboot doesn't run after coreboot).
coreboot-4.9-7f520c8fe6fc991df2c4e91f42843d4290744ebb Wed Nov  1 08:38:19 UTC 2023 romstage starting...
RTC: Clear requested zeroing cmos
coreboot-4.9-7f520c8fe6fc991df2c4e91f42843d4290744ebb Wed Nov  1 08:38:19 UTC 2023 ramstage starting...
Code: 0 eflags: 00010082 cr2: 00000000
eax: c1726e01 ebx: 00e20000 ecx: 0000000b edx: 7addd078
edi: fffbffff esi: 00000020 ebp: 00e30fd8 esp: 00e30f38
fffbffe8:    ff ff ff ff ff ff ff ff
fffbfff0:    ff ff ff ff ff ff ff ff
fffbfff8:    ff ff ff ff ff ff ff ff
fffc0000:    00 00 00 00 00 00 00 00
fffc0008:    00 00 00 00 00 00 00 00
fffc0010:    78 e5 8c 8c 3d 8a 1c 4f
fffc0018:    99 35 89 61 85 c3 2d d3
fffc0020:    00 f4 01 00 00 00 00 00
fffc0028:    5f 46 56 48 ff fe 04 00
fffc0030:    48 00 7a ff 60 00 00 02
fffc0038:    f4 01 00 00 00 01 00 00
fffc0040:    ff ff ff ff ff ff ff ff
fffc0048:    ff ff ff ff ff ff ff ff
fffc0050:    ff ff ff ff ff ff ff ff
fffc0058:    ff ff ff ff ff ff ff ff
fffc0060:    ff ff ff ff ff ff ff ff
